Xylicon
Posts: 249 Joined: September 21st, 2007, 4:48 pm
Post
by Xylicon » October 26th, 2007, 4:45 pm
Took apart the right clutch side of the case to install my new gear shift drum & seal & also to inspect the clutch.
Are these the tooth marks that you don't want? They look too bad to file down, I guess I'll fork out for a new basket any suggestions on brand and whatnot?
The clutch plates were almost toast too!
Any preferred type of clutch plates & brand I should get?
Xylicon on October 26th, 2007, 4:49 pm, edited 1 time in total.
Posts: 15404 Joined: May 31st, 2007, 6:39 pm
Post
by AlisoBob » October 26th, 2007, 4:46 pm
Posts: 8207 Joined: May 31st, 2007, 7:10 pm
Post
by britincali » October 26th, 2007, 4:52 pm
That basket is pushing it but I personally would hit it with a file, IMO you'll get a couple more years out of it with no issues.
Oh and that clutch look fine, they aint fried till they look like this!
On a serious note spend 20 mins with a file and slap in some new plates and it'll be good to go.
I run the EBC clutches 'cos im cheap, the barnett carbon fibers seems to be the shiznit.
britincali on October 26th, 2007, 4:54 pm, edited 1 time in total.
Post
by AlisoBob » October 26th, 2007, 4:53 pm
Post
by britincali » October 26th, 2007, 4:55 pm
Or if you are dripping in cash go buy a billett basket.........
Post
by AlisoBob » October 26th, 2007, 5:04 pm
$144 is dripping ? If it needs replacing, it needs replacing.. .simple as that.
OEM is $190
Post
by britincali » October 26th, 2007, 5:06 pm
$2.99
Xylicon
Post
by Xylicon » October 26th, 2007, 5:35 pm
Ok say if I wanted to get a new basket just because my money grows on trees. Most of the baskets I see don't have the big gear attached to the back, do I have to take the gear off my current basket and attach it to the new basket or do new baskets come with that gear attached?
It doesn't look like the gear will come off without a fight either.
Post
by AlisoBob » October 26th, 2007, 5:40 pm
Its simple, you drill out the rivets, and bolt it to the new basket.
Someone here should have a useable OEM basket for you....
Speak up hoons!
Posts: 4804 Joined: June 1st, 2007, 3:34 pm
Post
by lewisclan » October 26th, 2007, 6:35 pm
I have thrown mine away but you mite grind yours down and get a few more months out of it until you can get a new one
Posts: 3602 Joined: June 1st, 2007, 6:09 pm
Post
by iggys-amsoil » October 26th, 2007, 7:00 pm
Minium plate thickness is .112
You may just need a new basket. I'd replace it.
2013 Dodger Charger 5.7 Hemi
http://www.prisonplanet.com
Your Amsoil Customer #
350882
Xylicon
Post
by Xylicon » October 26th, 2007, 7:14 pm
Yea but the whole thing about removing the gear and bolting it to another plate is kinda high maintenance for me. I don't understand how that will work either.
Post
by lewisclan » October 26th, 2007, 7:40 pm
easy drill out the rivets and press out the sprocket then press it on the new hub and bolt it on done deal
Posts: 2915 Joined: June 1st, 2007, 5:07 pm
Post
by sabreguy » October 26th, 2007, 11:08 pm
Try Honda Parts Direct I just bought an OEM basket there with gears for like $175. Hard to beat that IMHO!!!!
Posts: 716 Joined: October 5th, 2007, 11:22 pm
Post
by HrcRacing » October 29th, 2007, 9:11 pm
lewisclan wrote: easy drill out the rivets and press out the sprocket then press it on the new hub and bolt it on done deal
And if you don't have a press, you can drive it out of your old basket, bag the gear and stick it in the freezer. An hour or so later, it will drop right in to the new basket.
Move the cushions over, put the backing plate on, lock tight the screws and you're good to go.
