Here is my clutch screw up
This is what you get when you are being an idiot and rush things.
Close up
My clutch basket after I filed it some
Do you guys think that the inner hub can be helicoiled?
Also the reason I ended up breaking off the bolt was because after I had the clutch installed I was checking to see if the clutch rod pushed out on the clutch when I lifted the actuator and I had alot of play between the rod and the pressure plate cover. So I thought to myself "self I must not have the clutches squeezed together enough so I will just tighten the bolts a bit more"
SNAP...............SHIT!!!!!!!!!!.............$@%&!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Throw things..................SHIT!!!!!!!!!!!!!!!!!!!...........IDIOT!!!!!!!!!!!!!!!!!!!
The rest you all already know!
How much play should there be between the end of the rod and the pressure plate?
DUDE!!!!
That has to be the worst grooving Ive ever seen on a clutch basket!!!!! I know I was the one who said "just file them out" but SHIT thats an unreal amount of wear!!!!!!
IMO I would try to find a new-used basket and hub from somewhere, if you file out those grooves theres gonna be nothing left :lol: :lol: :lol: :lol:
As for the play thing make sure you din't loose the little BB that goes on the end of the rod
TRASH IT BRO
BUT TO ANSWER YOUR QUESTION YEAH IT WOULD WORK BUT YOU WILL NEED TO BUST OUT THE GRINDER ON THAT GROVE
never seen a basket with them cool grooves. did you have to special order that? theres a torque spec on pressure plate bolts. without checking the manual i think its 6ft lbs
I have already ordered a new clutch basket, inner hub, lock washer and new bolts. I was just wondering about using the old ones as a backup.
I looked all over my manual and found no torque specs for those bolts but as a general rule 6 is probably about right. I knew that they were tight I was just surprised how much play there was between the end of the rod and the clutch itself. So I thought maybe I could squeeze the springs a bit more.
Yeah that a basket case alright, :? :lol:
I think the torque is 6-8 ft lbs. Better check it though. Thats something else I never torque, Just tighten them to a point.
I take back everything I have ever said about Brit being a cheap ass sod....
Saber is the new " Brit"
That basket gots ta' go...
AlisoBob wrote:I take back everything I have ever said about Brit being a cheap ass sod....
Watch it Chewie or I will have to come down there and kick you in the knee caps!! :lol:
bigpower
Post by bigpower »
Thats typical of an old machine like that, the way those grooves are in that basket. The one I pulled outta our KDX was just as toasty fried. I made one outta some 70 series aluminum and had it hard anodized. The one I ordered from Kawasaki finally came 2 months after I ordered it, like the end of May.
man, that basket is FUBAR!!!!
If you have any issues getting your replacement basket, I have one of my '86 that will fit '86-'89
Re: Here is my clutch screw up
sabreguy wrote:This is what you get when you are being an idiot and rush things.
I gotta ask what did you rush? I talked to you 2 months ago about the grooving issue!!!!!!!!!!!!!!!
2 months my ass!
But I was talking about rushing after I broke the bolt off in the inner hub and screwing the inner hub up not the grooves. I knew the basket was toast but I figured that I would install it and get a replacement on order so that way I could atleast ride it!!
sounds like the hoon way! Plus brit can't really get on anyones case about rigging a bike together to get to riding! :wink:
I get all wigged out when shits apart, I think the longest Ive had a motor stripped is about a week, I start loosing sleep after awhile :lol: :lol:
