Front Brakes
Front Brakes
Sorry if this in the wrong section. My front brake pull is soft and pretty much know the drill but have never rebuilt the front master cylinder. Tomorrow I am going to bleed them first, then check the thickness of the rotor and then maybe get some pads. Any other ideas? Brake is still working but the pull is soft and I want the KTM feel .........if possible
clean the rotor with scotch brite, clean the pads, I use a wire wheel. Fresh fluid, I use motul 600 degree stuff. I highly doubt rebuilding the master will change anything. After you change fluid and bleed it zip ty the lever to the bars overnight and that will let the system auto bleed if the bike is upright provided the master cylinder cap is on right and not over torqued. There are iar holes in the cap and a groove in the rubber diaphram that let the air escape.
On my last ride I almost when over the bars from grabbing my stock 2000 CR250 front brake going hot 4'th gear into a corner. Grabbed it a bit too hard
After you get it set up right, the first ride out before you get it dirty, do a few high speed hard stops. Don't drag the brake just use it hard at least 5X. that will get the pads seated to the rotor better provided they are not weird shaped from another rotor. If they are weird shaped they may need replacing or more than 5X stops.
exactly - using a vacuum pump style bleeder.beekums wrote:Try bleeding from the bottom up to the top
This:
http://www.motosport.com/dirtbike/produ ... gId=104306
or:
http://pitposse.com/mibrblkit.html
