That is exactly what I did, except mine were out of a 01 CR500 and I had 5mm added to each one. ( made of S/S the new ones )
The bike uses the Std swingarm bushes, which means Std part# for the bike.
I thought I had lost mine, found them about 30 minutes ago, I had put them in a safe place.
The safe place was in the engine cases where they should be, just forgot I put them there, it was that long ago.
Top job with your spacers though asteroid500, no small spacer parts to fall out and lose when you pull out your swingarm bolt.
