Ironman sprocket BOLTS REALLY REALLY suck!
The hex head is about 3/16" deep and strips out very easily.
Last edited by Disturbed on September 27th, 2009, 6:58 pm, edited 1 time in total.
- LAYNFRM
use a open end wrench on the nut to loosen it, while just holding pressure on the allen head. that way has worked for me for years. at first i tried just using the allen head to loosen it, and i was stripping them constantly. now, i never strip them.
01 XR650R Plated Supermotard
08 Polaris RZR
08 Polaris RZR
[quote="LAYNFRM"]use a open end wrench on the nut to loosen it, while just holding pressure on the allen head. that way has worked for me for years. at first i tried just using the allen head to loosen it, and i was stripping them constantly. now, i never strip them.[/quote
I did/do. With the pre-locktite [d] bolts they were broken loose and backed out 1/8"+ but that's when 2 bolt heads stripped.
X2!LAYNFRM wrote:use a open end wrench on the nut to loosen it, while just holding pressure on the allen head. that way has worked for me for years. at first i tried just using the allen head to loosen it, and i was stripping them constantly. now, i never strip them.
- lewisclan
- PVT. 1st Class
hummm go figurehoofarted wrote:X2!LAYNFRM wrote:use a open end wrench on the nut to loosen it, while just holding pressure on the allen head. that way has worked for me for years. at first i tried just using the allen head to loosen it, and i was stripping them constantly. now, i never strip them.
"the game of life of is not so much in holding a good hand as playing a poor hand well"- Rosco-Peeko
nice fucken attitudeDisturbed wrote:Yeah, you guys are fucking perfect and so are Ironman sprocket bolts.
like they all said on ALL BRANDS OF SPROCKET BOLTS, only use the allen side to hold it steady, apply all torque to the nut.
- caseyracing222
I must side with Disturbed on this issue, I havent used iron man sproket bolts before, but I have used msr and they suck, the metal is very brittle and does strip very easily when installing them correctly, also they came loose after eveyride. The point is some things are best bought oem and sprocket bolt are one of those things.
-Jake
Clearly another hack doing it all wrong with improper tools. You just need to do it correctly like I know how to.caseyracing222 wrote:I must side with Disturbed on this issue, I havent used iron man sproket bolts before, but I have used msr and they suck, the metal is very brittle and does strip very easily when installing them correctly, also they came loose after eveyride. The point is some things are best bought oem and sprocket bolt are one of those things.
You need to just hold the allen side while applying torque to the nut side. If you do this properly every bolt made on the planet will spin loose with ease and never strip. I don't know why someone else hasn't pointed this out earlier on this thread.
- caseyracing222
yup, I buy all oem honda parts because they are reasonably priced, but for yamaha I buy what I can afford the cranks are close to $400 and pistons are $200, I dont understand why Yamaha parts are so overpriced, usually honda parts are only a few more dollars than aftermarketAlisoBob wrote:Most everything....caseyracing222 wrote:The point is some things are best bought oem and sprocket bolt are one of those things.
-Jake
- caseyracing222
Im no hack and I know how to install sprocket bolts, ive been wrenching on bikes for 13 years...Disturbed wrote:Clearly another hack doing it all wrong with improper tools. You just need to do it correctly like I know how to.caseyracing222 wrote:I must side with Disturbed on this issue, I havent used iron man sproket bolts before, but I have used msr and they suck, the metal is very brittle and does strip very easily when installing them correctly, also they came loose after eveyride. The point is some things are best bought oem and sprocket bolt are one of those things.
-Jake
And after my almost 40 years of fooling with bikes it's not impossible to see way I got a wee bit cranky with the redundant posts.caseyracing222 wrote:Disturbed wrote:Clearly another hack doing it all wrong with improper tools. You just need to do it correctly like I know how to.caseyracing222 wrote:I must side with Disturbed on this issue, I havent used iron man sproket bolts before, but I have used msr and they suck, the metal is very brittle and does strip very easily when installing them correctly, also they came loose after eveyride. The point is some things are best bought oem and sprocket bolt are one of those things.
- caseyracing222
- thestuz
he has a good point. the shallow hex head is not the best design imo. i too had the same problem with one of mine. even though i was using the hex side just to hold it, the bolt can still spin in the hole. therefor the pressure you apply to the nut finds its way to the hex head on the other side. i prefer metric nuts/bolts anyday. but as already said, use correct tensile allen keys that are the right fit and make sure you have some locktite on the nuts, pref the stuff that doesnt dry while your wrenching. good luck
01 CR500
98XR600
94 FIREBLADE
ESTABLISHED 1977.
01 CR500
98XR600
94 FIREBLADE
ESTABLISHED 1977.
