need a little help with air box on 02 conversion
Im almost done with my 02 conversion but the last problem i have is the carb and the air box boot are not even clos to connecting the carb hits the shock sping so im not sure what u guys do to fix this but if u can help that would be great..and the motor is a 88 thanks.
with the right intake boot in the motos side it should basically bolt right up. Tighted the motor side, and the air boot will be slightly angled with a little more lip hanging over the top of the carb and not enough over the bottom. just push the carb up a little so the boot lines up properly and while holding the carb, tighted the clamp. after being held like that for a while, the boot will conform and the next time you pull the carb, it will go back in like oem.
