bought a lower end for the right side case got it apart and was checking the rod clearence was over the limit so pressed it apart and found a bad thrust washer it put a little grove in the rod so i was looking at the rod groove and thought i saw a hair till i tried to wipe it away OOOH!!!! crack!!! its at about 9-10 0'clock starts in the bearing journal and runs up the thrust side. there NO WAY!!! anyone would have seen that on the crank, would have put a nice window in someones case for sure im glad i cought it
what is a good rod kit to use
rod on crack
rod on crack
00'cr500 trailclimber
93'cr500 beater
92'cr500 hillclimber
89'cr 500 bent frame
04'crf230(wifeys)
02' cr125(sons)
02'sx65(sons)
03'xr50(sons)
93'cr500 beater
04'crf230(wifeys)
02' cr125(sons)
02'sx65(sons)
03'xr50(sons)
I think dudes had figured that a new crank was only $60 more than getting a rod on, its mentioned somewhere here, and there was a honda part#
