Drilling out my 85
nmdesertrider
Drilling out my 85
Post by nmdesertrider »
Hey, what size bit should I use to drill out my 85 motor so I can stick a bushing in there... should I use one from the 125? Its going in a 04 crf450 frame.
Which bushing are you refering to the ones that are pressed in the case halves?
nmdesertrider
Yeah, so I can put in the bigger swingarm bolt.
It seems like the two options are to drill out the cases and put in bigger bushings, or to just have the original bushings drilled out.
Which one is the best option?
I was looking at the yamaha bushings--
eyesky2002
Post by eyesky2002 »
nmdesertrider wrote:I was looking at the yamaha bushings--
Why Yamaha? Sure you can still get the ones for the CR from Honda parts direct or worse case from SH???
MXMotoworx.com
2003 Honda CR500AF
You cant buy just the bushing, it comes already pressed in the case half.
I took my 87 style bushing and the swingarm bolt to a machine shop to have a set made.
Yamaha? I guess that's ok if your buying a Piano. :lol:
AJ at SH might be able to help you with loose bushings but only AJ forget asking anyone else there! I know he's helped other hoons in the past he's a good dude and if he's got them he'll hook you up.
The Dealer doesn't sell the bushings as far as I know you would have to buy the cases.
Do you have access to a machine shop and a good machinist? If you do "bore" your bushings you won't be able to "drill" them. Even if you got bushings from AJ you would still need to "bore" the cases.
If all else fails I know a Machinist that knows a thing or two about a thing or two :wink:
MTNielson
Post by MTNielson »
Mike at TeemTrubble bored mine out. They work great.
You should be able to pop out the bushings and send them to him.
______________________
'03 CR450/500 conversion
'97 CR250/500 conversion
'04 CRF250R
nmdesertrider
Okay bear with me now, I'm not the sharpest nail in the box... are you talking about part #25 in the pic? It's really thin, I don't see how you can bore it out but I trust you guys.
Re: Drilling out my 85
nmdesertrider wrote:Hey, what size bit should I use to drill out my 85 motor so I can stick a bushing in there... should I use one from the 125? Its going in a 04 crf450 frame.
That drawing you posted doesn't apply to a 450 coversion :roll:
nmdesertrider
I am trying to identify the bushing you are talking about.. I thought you meant off the 85???
nmdesertrider wrote:Okay bear with me now, I'm not the sharpest nail in the box... are you talking about part #25 in the pic? It's really thin, I don't see how you can bore it out but I trust you guys.
You won't need any of this stuff but it would be item 12 in the first drawing you posted!
nmdesertrider
Okay Mike thanks. I thought there was something I could with the 85 bushing and I have been scratching my head and saying WTF? all night.
I'm asking stupid questions so I avoid doing stupid things!! :lol:
No such thing as a stupid question!
Just stupid mistakes..... :wink:
But you still need to bore the case bushings or find new bushings and bore the cases. The swing arm bolt from your 450 is 2mm bigger than the bushings in your 85 CR500 cases if I remember correctly.
Uzi
Post by Uzi »
Yeah the 85 has 15mm bushings and the newer stuff has 17mm talk to AJ at Service Honda he hooked me up with a set of the newer style bushings. I don't know if he's got any more laying around but he would be the one to ask because like others have said you can't get them as a separate part. Here's a shot showing the difference
1982 XR200
1985 CR500 86' Motor
1990 CR500 85' Motor
2000 CR250
Uzi wrote:AJ at Service Honda he hooked me up with a set of the newer style bushings.
:urock: :urock: :urock:
nmdesertrider
I got some bushings from a crf450 that grenaded... what size bit should I use to drill out the holes for the bushing?
nmdesertrider wrote:I got some bushings from a crf450 that grenaded... what size bit should I use to drill out the holes for the bushing?
That stuff is offly hard, a regular drill isn't going to cut it.
Could it be that Yamaha or another would work?
nmdesertrider
I am drilling out the cases, not the bushings.
a 13/16" bit worked perfect for me! :wink:
nmdesertrider
Thanks Danny. Damn bit was 23$ :shock:
n/p
ya, I remember paying like $35 for mine, I bought it when I was converting my friends old 350z to a manual trans and had to drill the hole in the crank for the pilot bushing... that was a brutal project that we had to finish by the end of the day :shock:
smokindodge
Post by smokindodge »
I know this one has been beat to death fellas but I've got a couple questions on it. I have a guy who wants to buy my 92 steelie chassis. He's got an 88 right now he wants to put his motor in the 92. I am just wondering what it's going to cost him (ballpark) and how much work to get the bushings done. Has he got to split his cases to get the bushings out? What's the easiest way to get this done all of you who have been through this.
$40 plus shipping to bore the bushings
smokindodge
what about getting them out of the motor? I can't picture it in my head, if I ever even knew that is.. Will he have to split the cases?
take a punch or even a screw driver and tap it out from the other side.
