Removing Flywheel
JakeBoucher
Removing Flywheel
Post by JakeBoucher »
The Flywheel on my 85 CR500 has a little corrosion I would like to clean up. Pulled the nut off and obviously it didn't come off with a little tug. Anyway, where do I get a puller or what I need to get it off? Can I just buy a bolt with the correct threads, or would that be hard to find?
In the end were all just chalk lines on the concrete, drawn only to be washed away. - Ivan Moody 5FDP
Nodge
Post by Nodge »
You need a flywheel puller.
If you try anything else, you will be sorry.
JakeBoucher
Where do I get the Flywheel puller? I looked on a couple sites and they don't carry one for the older models.
Nodge
Post by Nodge »
I ordered a whole kit full of pullers on eBay.
All you need is the 27mm puller for CR's.
Like so:
http://item.mobileweb.ebay.ca/viewitem? ... 0567958788
http://www.bikebandit.com/motion-pro-ma ... -left-hand
Any motorcycle shop can order you one.
JakeBoucher
Ok, thanks alot.
