Short Rod Piston with long rod compensated pin height?
81cr450
Post by 81cr450 »
Like the title says, Short Rod Piston with long rod compensated pin height? Anybody make one? Any demand? Its like $1000 or $2000 buy in for custom pistons aint it? Or are custom rods cheaper?
Cylinder spacers are ... :shortbus:
Also can I just change the clutch pushrod from a newer motor & add the bearing? On an 86 of course
the bearing will not fit behind the pressure plate of a narrow basket setup, likely the only reason they went to the wide one.
no to the pin height, too much skirt thrust if its moved.
81cr450
Post by 81cr450 »
Never thought of that, just that banshee s & 250r raise the pin height for longer rods seemed like a good idea.
Skirt thrust does sound like it could be fun though :twisted:
