Case bushing needed (1986)
blackz34
Post by blackz34 »
Like title said, I need a case bushing where the swingarm goes. This is to fit in a 1986 case.
Thank you
You're looking for one stock to an 86, not to update it larger correct?
I'd have 1986 ones
blackz34
Post by blackz34 »
Actually it is to enlarge it. Is the OD of the earlier ones larger? I was debating on boring the bushing or the casing...
Also, Yamaha is selling the bushing unlike Honda or the other make, I found that the pre-2001 YZ250 uses 17mm swingarm pivot bolt, but I don't know the other dimension on the bushing, may be a good start too...
the 1989+ bushing will not fit in the case without boring the hole first, the older bushing is too thin to bore and expect it to not shatter.
blackz34
Post by blackz34 »
I ordered the Yamaha bushing to see, I'll post the result when I'll receive them.
That'd be great
MojaveRider
Post by MojaveRider »
Any updates on these? I have two '87 engines that need the bushings swapped.
blackz34
Post by blackz34 »
They are B.O. :( My friend has put them in an order he made but his order was held because of these so he cancelled them. I migh re-try to order them myself and wait.
blackz34
Post by blackz34 »
Roostius_Maximus wrote:That'd be great
Update here:
http://bannedcr500riders.com/board/view ... 459#141459
