GEN 2 250/500 RADIATOR ?
02widowmaker
Hey guys new on here. I am in the middle of a gen 2 build and have some questions on radiators for this build. Are you reusing the 250 rads? Right rad bottom crossover is close. Frame is all done I"ll post pics soon.
TWO STROKES ARE FOR MEN, FOUR STROKES ARE FOR LAZY MEN
- freeride588
Welcome man you should head over to the introduction section and say hello. To answer your question you use the 250 radiators. Some of the outlets you have to modify. Some people cut them off and weld new ones on but i just carefully heated the bends ans stuck a wood dowel in the hole and bent them slowly without adding to much heat as the aluminum is super thin.
Kevin
