http://phoenix.craigslist.org/evl/mcy/2732556138.html
neat idea.  i like my yz250 oring set up, but it is the cyl that is grooved, which i like better, then I can mill the head at will.
						o-ringed heads
- maddog1927
I can o-ring heads or cylinders
- asteroid500
The head gasket has larger holes for the coolant on the exhaust side of the cylinder for more flow, with o-ring, has anyone experienced any issues with the intake side of the cylinder running cooler which may cause an out of round condition?
Or, when o-ringing the head, are the water jacket openings welded and drilled for the corrected flow?
				OUTKAST INC.
HAVE BEEN RUNNING AN O RING HEAD WITH NO PROBLEMS SINCE I BUILT MY AF , FINE WOODS RIDING ,FINE ON MX TRACK AND FINE IN THE DESERT...IN FACT THE BIKE RUNS ABOUT 20 DEGREES COOLER THAN IT DID WITH THE HEAD GASKET ... I BORROWED A QRC HEAD FROM A LOCAL 500 MINI SPRINT RACER, HE HAD AN EXTRA SET OF ORINGS THAT I BOUGHT 15 BUCKS,,, TOOK IT AND THE STOCK  HEAD TO A LOCAL MACINE SHOP AND 45 BUCKS LATER IT WAS DONE. HAVE EVEN HAD TO PUT A LITTLE DUCT TAPE ON ON RAD IN 35 TO 40 DEGREE WEATHER TO GET ENOUGH TEMP TO CARBERATE PROPERLY..ONLY TRICK IS YOU NEED A MACHINE SHOP WITH A BIG ASS LATHE TO CHUCK IT UP.
						Don't yell at me man, I was just wonderingOUTKAST INC. wrote:HAVE BEEN RUNNING AN O RING HEAD WITH NO PROBLEMS SINCE I BUILT MY AF , FINE WOODS RIDING ,FINE ON MX TRACK AND FINE IN THE DESERT...IN FACT THE BIKE RUNS ABOUT 20 DEGREES COOLER THAN IT DID WITH THE HEAD GASKET ... I BORROWED A QRC HEAD FROM A LOCAL 500 MINI SPRINT RACER, HE HAD AN EXTRA SET OF ORINGS THAT I BOUGHT 15 BUCKS,,, TOOK IT AND THE STOCK HEAD TO A LOCAL MACINE SHOP AND 45 BUCKS LATER IT WAS DONE. HAVE EVEN HAD TO PUT A LITTLE DUCT TAPE ON ON RAD IN 35 TO 40 DEGREE WEATHER TO GET ENOUGH TEMP TO CARBERATE PROPERLY..ONLY TRICK IS YOU NEED A MACHINE SHOP WITH A BIG ASS LATHE TO CHUCK IT UP.
				OUTKAST INC.
