Vortex Ignition
Vortex Ignition
Does anyone run this ignition? If so, what are the results of the change. Good,bad, no change. Thanks, Bob
I have this ignition on mine. I'm running it with a 2000 CR250Does anyone run this ignition?
stator and flywheel.
Unfortunately, I can't give you any info on changes since I
started out with it. I can tell you it has a lot of capability
in regards to multiple maps available. I have a hybrid 2000
CR250 map that compensates for the differences between
the 250 and 500 pulse generator location.
If you are rolling in dough, you can buy a programmer and
software from Vortex and create your own, or you can do
like I did and take it to a friend that has one and let him
do the work while you provide the beers. Also, Vortex will
reprogram your ignition, just tell them what you want.
I used to run JD ignitions on my 250s and this is every bit as
good.
dogger
- gregrobo
i run the vortex with the stock 500 maps programed in and love it it is night and day over the stock 500 ignition it starts easy has pleant of over rev and also lets the bike idle lower while climbing rock or on loose ground ours is a x10 with bar switch
98 yzfr1
05 crf 500 race tech goldies
2010 rmz 500af
01 banshee
98 yzfr1
2010 rmz 500af
01 banshee
if you get one get vortex to put this map on it, change the 8000+ if you want, but the important part of the map is the 250-1000 rpm
the lime green one
fixed it
the lime green one
fixed it
Last edited by 2strokeforever on October 27th, 2011, 10:04 am, edited 1 time in total.
- gregrobo
what map are you talking about2strokeforever wrote:if you get one get vortex to put this map on it, change the 8000+ if you want, but the important part of the map is the 250-1000 rpm
98 yzfr1
2010 rmz 500af
01 banshee
98 yzfr1
2010 rmz 500af
01 banshee
