after revamping an 87  500 for my best friend we realized it would need a new topend bafore this next season,we have everything set (piston,v-force reeds,39 carb) and given his past with drag cars and such, he is good with a drimel,so a little porting is on the way.
he brought up an issue.the 85 has 7.4 to1 comp,the 86-7.0 and from 87 on the comp is 6.8 to1.my reserch showes the head is the same as well the head gasket is the same part 3 from 87 to01.
the base gasket was a differtent # for 85,86 and 87 but have all been superseeded to the current mac part#.
i have 3 base gaskets,oem,atheena and k&s,the atheena measures .200,the oem measures .210 and the k&s measures .225.
will the atheena give more compression,butt change the port timming to adversly affect the band.  he is a dezzert rat like me and anything butt wfo will not due.
						BASE GASKET AND COMPRESSION
				skidplate29
you must have your decimal point wrong. the difference between the thinnest (athena) and thickest (k&s) is .0025 ? thats almost nothing and really wont change anything. now adding a whole extra .020 gasket does add 2* on the port duration. but i dont recomend stacking gaskets if it can be avoided. install 1 oem gasket and work from that point
