Linkage Bearing Maintenance
- NightBiker07
So, how often do you guys service your linkage bearings? I just ripped apart mine after rebuilding them a year and a half ago, and they were in need of it. still lubed and moved freely, but were starting to get dirty.
What are your schedules?
Once in 16 years.
i just build a new bike
- NightBiker07
If i could afford it lol. I still dont have the motor I want in my frame LOLRoostius_Maximus wrote:i just build a new bike
Back in my day, they didn't have linkages, swingarm bushings yes.
If I only had 1 or 2 bikes to ride all the time I suppose they would get regular maintenance.
As it is now, no single bike of mine gets used that much.
I don't even know what the manuals call for, I guess that should be the guideline.
- thestuz
not if you have grease nipples.AlisoBob wrote:Pressure washer = more maintenance
i usually pump a few squirts of fresh grease in during tyre changes or every 6 months. the only trouble with this method is excess grease messing up the areas once it squeezes out all the old stuff. a can of degreaser and a pressure clean usually get it all. you can see where i have missed.
now its just the spherical bearings in the shock that i have to grease.
									do it!...  cos if you dont, youll spend the rest of your life thinking about it anyway!
01 CR500
98XR600
94 FIREBLADE
ESTABLISHED 1977.
						01 CR500
98XR600
94 FIREBLADE
ESTABLISHED 1977.
