Oversize Radiator
- DieHard2Smoke
Oversize Radiator
My '85 500 is boiling coolant quite often on this trip to the dunes. Ive rigged a temporary overflow bottle setup that is working pretty good right now but would rather have a permanent solution, and not have to stop and wait for motor and coolant to cool down every so often. I did use a coolant flush and got some corroded stuff came out, but still boiled coolant. I think these radiators are junk, and yes im running a cold plug, and my jetting is on.
Have any of you ran a oversized radiators and have any suggestions on brands?
Also do any year 125 or 250 fit the 500?
Id rather get a new set of radiators to eliminate any possibility of corrosion, but if i can get a set cheap, ill run them.
- DieHard2Smoke
ive looked at converting to waterless coolant... but these radiators are 26 years old and i think its time for these to go. you should of seen the amount of crap that came out, 2 of the internal fins were almost clogged with corroded stuff.
tho i will be converting my n2o skidoo to evans waterless npg r
britincali wrote:Rads are blocked.
X491
- DieHard2Smoke
CLR works good
- DieHard2Smoke
well got rads clean, started pouring some water wetter equivalent in... and coolant started dripping, thought it was a loose hose clamp at first but they were all tight. come to find a crack in my right hand side case cover right above the water pump between to hose outlets..
so if anyone has a spare cover laying around, ill gladly buy it from you. couldnt find any on fleabay. atleast now i have the excuse to fully tear down this bike and give it a full restore, pics later tonight, going to ride the yz 250 for awhile.
- DieHard2Smoke
well the drtbiking gods wanted me to stay in the hotel today. got a couple of hours of riding in, and once i got to the other side of the sand dunes the clutch cable broke on my yz250...
not a huge set back but i had to jam it in gear and ride back to the truck, hopefully the local dealer here has a cable, because im all out of back up bikes.
