I am sure I read it here somewhere but the search did not pull it up.....
What is everyones doing to get the Gen 4 CRF250 brake pedal to clear the 500 cases. Are people bending the 250 pedal, or using a CR250 pedal?
Brake pedal clearance
I use the 1997-99 cr250 pedal and shifter, it fits around the clutch cover better without the pedal sticking way out. The shifters pinch bolt goes in at an angle so when installing on a AFC you can take it on and off without moving the motor.
I like my brake pedal and shifter to be just right or i have problems, because of past broken bones in booth legs and ankles.
I did a 450 conversion , and the brake pedal from a 450x clears nicely no bending needed.
Uploaded with ImageShack.us
2000 banshee, 2006 cr500AFC, 1987 LT500r
