i wanted a presure suit so i went to the dealer to find what one fit me best, planning to then buy it at rockymountain, i ended up getting the thor impact rig se, but i guess the dealer saw that i was buying a bunch of stuff but not from them so they gave me the same price as rockymountain could
anyway i like it , it has a bunch of pads and a built in kidney belt
also got a fox camelbak/backpak from rockymountain for $50
http://www.rockymountainatvmc.com/produ ... ries-Rider
the water bite thing is really good, different than the picture, dosent leak holds 3l/102oz lots of padding on the back, lots of room
moose front brake levers suck, thinner than oem and made outa garbage aluminum. tusk ones are thick and strong, but if i was rich id go with oem
enduro engineering KTM magura clutch lever, makes pull easier , has a bearing in the pivot same shape as stock magura . it has a little more leverage. and ive heard they make the master cyl wear faster, guess ill find out if it dies ill just replace it with a 8.5mm master and use the regular lever
after using tubliss, i will never go back to tubes, there that good
and im using a moose airfilter and love the design, cheap too ,cleaned it quite a bit and its not coming apart ant the extra ring to help it seal better
beware of twin air tho
also im looking for a new set of rear brake pads, the back wore out (almost metal on metal<.5mm) in 3 months, but i hardly use the back and the front is still over half life left?????and i use the shit otta the front. i already checked for dragging , none the wheel spins freely rotors straight, caliper is straight
but do i want carbon, kevlar or sintered metal?
