GSS full race porting vid
- tacogrande
Taking the GSS motor for a rip...It's really a great motor. See for yourself.
Socal Hoon
- caseyracing222
at least im not the only oneI like how he grabs it a few times, looking for 6th.....
i have better luck using one finger, because i need to hang on tight,your supposed to use the clutch but 2 fingers only you lose control over the bars using 4
the one downside i found is if i always have a finger on the clutch when i bail my clutch fingers get mangled
- tacogrande
Sometimes I downshift without a clutch, but isn't it hard on gears to upshift while pinned without a clutch? The springs are heavy in the CF clutch Glenn put in, and the cable is worn, so no way I could use one or two fingers on the clutch. It's running a little fat on the top end (100+F), but it's perfect when it's cool out. It was shot along Irwin road outside of Barstow with a GoPro HD cam. Sometimes I talk to my bike when I ride, don't You? lol.britincali wrote:
Sounds good!
You use the clutch WAYYYYY more than I do, I just use it to start and stop
Is that by Ft irwin rd?
Socal Hoon
tacogrande wrote:
Sometimes I downshift without a clutch, but isn't it hard on gears to upshift while pinned without a clutch? .
Just drop the throttle for a split second
A fresh well routed clutch cable is a must with the barnett other wise your arm ends up looking like popeye
2strokeforever wrote:true 500 riderSometimes I talk to my bike when I ride, don't You?
I talk all the time but normally its "fuk fuk fuk fuk fuk fuk fuk fuuuuuuuk...."
- tacogrande
I think I said "GO MOTHER FUCKERRRR!!!! NEED MORE POOOWWWWEERRRRR!!!!" Or something to that effect. Hmm. I'll have to try your shifting method out and see if it's faster, I do need a new cable for sure though. And brake pads, I don't have any back brakes at all, but who needs those.britincali wrote:2strokeforever wrote:true 500 riderSometimes I talk to my bike when I ride, don't You?
Socal Hoon
Thats ok for what he's doing but not for the start of a race. You will find yourself in last place.britincali wrote:tacogrande wrote:
Besides,.......... It sounds good for the video.
