WTB 85 crank
jeffatc250r
WTB 85 crank
Post by jeffatc250r »
WTB 85 crank
I *think* they are the same from 84-86.......Looking for something that is useable and not in need of a rebuild. been long enough and need to get my 500 powered trike back up to par. Shoot me a shipped price to mass zip 01005 Thanks Jeff
jeffatc250r
Will also entertain a whole bottom end from 85-86
kball1313 has one, pm him
so you know, you can use an '87+ crank with the cometic spacer.
south central hoon
Post by south central hoon »
dannygraves wrote:so you know, you can use an '87+ crank with the cometic spacer.
that must lower the compression quite a bit, no?
na, TDC is the same and the port locations are the same as '87+ on '85-'86 jugs.
jeffatc250r
^^Thanks for that lil tidbit of info, that does indeed open up a few more doors.
south central hoon
dannygraves wrote:na, TDC is the same and the port locations are the same as '87+ on '85-'86 jugs.
:cool:
