Gen 2 kickstarter
Gen 2 kickstarter
My 2nd generation AF CR500 is in need of a kickstarter. I had been using the stock kicker for the 500 motor with no issues, but I can no longer get it from Honda and now it is sloppier than a 2 dollar whore.
What 250/450 kicker would have the right bend to tuck in nice and not hit the pipe? I've tried a kicker from my 04 CRF450, but it hits the frame when trying to tuck it in.
Ported&Polished wrote:I'm more interested in where to get that 2 dollar whore. I mean geeze, only 2 dollars? I could find a way to make it work, surely there is some oriface on her that is less sloppy. And from what I hear, if you use a ham, and pull the bone out, she would good as new.
There are a few in barstow that would only cost you a beer......
I ran into her when I was in Barstow.britincali wrote:Ported&Polished wrote:I'm more interested in where to get that 2 dollar whore. I mean geeze, only 2 dollars? I could find a way to make it work, surely there is some oriface on her that is less sloppy. And from what I hear, if you use a ham, and pull the bone out, she would good as new.
Yeah it doesn't give the same leverage like the stocker.ShanMan wrote:any 250 kickstart lever is going tobe too short and cause you much grief...ask Iggy.
And another tip, if one wants to do the extra work. I did.
On the inside of the kicker assmebly, offset the spline one tooth. Yeah you'll have drain the coolant and remove the right side case, maybe the clutch too.
Shanman! you goin to Glamis?
Last edited by iggys-amsoil on October 7th, 2007, 1:52 am, edited 1 time in total.
2013 Dodger Charger 5.7 Hemi
http://www.prisonplanet.com
Your Amsoil Customer # 350882
