Look rich as fuk but standing it up at the 600ft mark takes some ponys...
Serious horsepower
Serious horsepower
- NightBiker07
- arleybeer40
- Rosco-Peeko
Minus the airdam....he had massive lift. So if I added a wedge to my 500...pointing it slightly up...romped on it let the airflow lift....what is the variable? Mad power on tap or aerodynamics?
Drop the flaps on a C-17 with 4 engines cranking out 40K in thrust....huge lift!!! As speed is increased, an airfoil is created......think about it. A vespa with a gsxr motor in it and the right angles......that bitch will fly....
Simpler terms...eat Taco's Guamos Wet Picadillo Burrito. The next day.......the turd produced a size of a weight lifters arm will break the speed of sound and crack the porcelain on the good ole shit box as you howl god's name numerous times under serious distress. Propellant or aerodynamics?
This problem is easier than it seems...
