Ahh, what a difference!
bigpower
Post by bigpower »
Finally found some time to change the spring rates in the '01. I know its been hashed over many times elsewhere, but theres nothing like getting correct spring rates for your weight before you even give yourself a headache trying to find the sweet spot with the clickers.
Put some time in on it yesterday, much better than the first time I rode this thing.
If you weigh more than 180 lbs, you prolly need to put heavier ones in there.
Yeah the last two races and saturdays trail ride just shows the awesomeness of having them done. Then getting the sag right and a couple of clicks one way or the other. Way :cool:
2013 Dodger Charger 5.7 Hemi
http://www.prisonplanet.com
Your Amsoil Customer # 350882
I wonder what my spring is rated for. It's a Eibach from the previous owner. Is there a way to tell what it is meant for? Are there numbers on them ussually?
yes
lewisclan wrote:yes
But I have seen them on the flat ends, so the spring has to be off. :x
