Clutch cover paint
- maddog1927
Clutch cover paint
What paint have you found that works well, and looks oem for the last generation metalic grey colored clutch cover?
i use that vht brake caliper paint
I've never had any paint hold up to the boot rubbing. MFDB recently used some super badass gun coating on his clutch cover, it lasted a while, but within 3-4 rides it started rubbing off. The oem color is very similar to the color they call "cast aluminum". I always just bead blasted mine, but since its a mag alloy it turns a dark gray color.
