Case Studs?
Case Studs?
I am putting a new motor together, and was putting the studs in to the new cases and the threads seem screwed up.
On the case side, the nuts thread on smooth, but on the cyl side they start, but get tight/won't thread without force.
Studs and nuts are new OEM Honda, fresh out of the baggie and all 4 are the same way. The treads on one end match the other by laying them into each other. Normal or did I get 4 junk studs?
The threads *appear* to be the same on either side. I layed the case side of one and cyl side of another together and they matched. I also took a peak at the other motor I have as well as a left case and I have the correct sides of the studs.
I have a hunch what I'm seeing is normal, since I've got 4 new, OEM studs and they're all the same. If I had one acting odd, I would be inclinded to buy a replacement. I just want to see whats up before I assemble and have torque values messed up due to the drag.
The cylinder studs are definately bigger on the jug side...
