Having a clear out and found these left over from my '83 CR480R that got sold and sent off for restoration...
(2) Uni air filters
Head and base gasket
(2 sets) front brake shoes - (1) USED
Rear brake shoes
OEM 1/2 Throttle housing
OEM Throttle cable
OEM Throttle tube
(2) Clutch cover gaskets
OEM axle stand
OEM exhaust clamp (pipe to silencer)
OEM pipe spring (rear)
(2) pipe springs
OEM brake trunion (rear)
Front wheel bearings
(2) Chain slider (front)
Chain guide rubbers (rear)
OEM gear lever oil seal
Steerer tube
Rear axle(s) - USED
OEM Swing arm bolt
(2) OEM footpeg pins
OEM carb needle
OEM fuel tap o-ring
Pro-Link swing arm decals
This is all stuff because a) it is hard to find or b) will wear out on your bike. PM me if interested. Will sell the whole lot or item by item. Any reasonable offer accepted.
GARAGE SALE - 1983 HONDA CR480R PARTS
- redrocket190
Michael Stiles
2007 Honda CR500R-AF
