03 450 conversion finished
nmdesertrider
Post by nmdesertrider »
I was surprised at the differences between the 03 and 04 frames- the 03 seems roomier than the 04 and the conversion is easier.
I did a couple things different- I put the y much lower this time- it just clears the pipe. The y fits on the drop piece with very little grinding and lined up nice and square- plus you don't have to worry about clearing the radiators. I have a hunch that this is the way to go with the gen 4 frames too.
You can just trim the drop piece so the top of the Y touches the weld on the lower radiator bracket.
I switched the head stay to a gen3 two stroke style mount- I welded a block to the frame and used 125 brackets.
Shans front motor mounts are really well made, but I had a hard time getting the right bolt for the front to fit so I fabbed together a piece with regular thickness that would allow the stock bolt.
Started her up tonight and the bike vibrates much less than my 04- will be riding it tomorrow.
03 CRF450/85 500
