extending swingarm need pictures and ideas
r1yfz
Post by r1yfz »
Im looing to extend my stock swingarm.... it will mostly be a flat drag/dune bike...
I will be useing 2 swingers to create one..
Im looking for picture off some cr500's with extended swingarms and please list how far out back it is... im trying to get ideas of how long to do mine.
blownbillybob
Post by blownbillybob »
look on craigs list SF bay area lefty list his on there all the time i think there $380.00 bolt on with 3 slotted adjustment holes no rear brakes but i think for $50 more he will machine it for brakes!! hes out of lodi,Ca :lol:
00'cr500 trailclimber
93'cr500 beater
92'cr500 hillclimber
89'cr 500 bent frame
04'crf230(wifeys)
02' cr125(sons)
02'sx65(sons)
03'xr50(sons)
r1yfz
Post by r1yfz »
i can build my own for a fraction of that cost
caseyracing222
Post by caseyracing222 »
r1yfz wrote:i can build my own for a fraction of that cost
He includes an axle, snails, and chain slider. I have the one with the brake quality stuff, I just wish that lefty would use Metric Hardware and not SAE :D I'll get you a pic later if Paul doesnt beat me to it
-Jake
theres several designs of extensions depending who made them but the ones ive seen were pretty simple in design. the problem with using 2 swingarms to make one is they will be in a fixed position and youll have almost no adjustablility, if you know the exact amount of extension you need then it would be fine but youll be shit out of luck if you want to shorten or lengthen it for different terrain. a chunk of billet 6061 and drill press is really all you need to make some adjustable ones. if you have acess to more sophisticated equiptment it would probly be easier but not necesarry.
this was a local dudes yamaha chassis. these are more sophisticated than some ive seen but you get the idea. on the steely swingarm you can pull out the end pieces and slide the extension inside, however on the newer honda swingarms you cant slide the extensions inside.
r1yfz
Post by r1yfz »
it will be on a stellie.... i wil be dynoing the bike to see what it makes before i decide how long... but im guessing it will be in the 6-8 over range on a 14 viper
Mine is adjustable from 5.5-9.25" and I run it around 6.5", anymore than that and the loss of traction is a PITA.
r1yfz
Post by r1yfz »
any pictures?
caseyracing222
100hp honda wrote:this was a local dudes yamaha chassis. these are more sophisticated than some ive seen but you get the idea. on the steely swingarm you can pull out the end pieces and slide the extension inside, however on the newer honda swingarms you cant slide the extensions inside.
That bike has soooo much travel in the front...... :roll: looks like he needs heavier fork springs
-Jake
r1yfz wrote:any pictures?
Ill look..
You dont need to machine or weld anything to run a rear brake, the caliper rests on top of the swingarm and once the axle nut is tightened it aint going anywhere, all you need is a longer hose.
caseyracing222 wrote:That bike has soooo much travel in the front...... :roll: looks like he needs heavier fork springs
your right and ill pass the info along. perhaps he could use some of your magic fork bleeders/fuel filters :?
brits setup would work tits for you. not sure where he got em though
r1yfz
Post by r1yfz »
thanks brit!!
How did that tire hold up? i will be running the same one. Did you have any wheelie problems while launching hard in the first 300ft with that setup?
100hp... i think i remember brit posting somewhere that he got those off a hillclimbing forum? could be wrong though.
Got them from a guy on www.kingofthehill.org
It works perfect in the sand full throttle + juice second gear launches are possible with the front just barely coming up.
r1yfz
Post by r1yfz »
do you have anyidea how many links are in your chain? or where you got your brake line?
The chain is a 120 link plus I added 10 or so more links from an old one, I got the brake line from glen at GSS he stocks them :D
hillclimbjim
Post by hillclimbjim »
front lines work but a little long
caseyracing222
or maybe he can follow your expert porting advice :? lets not go looking for a fight.... Back on topic. I can get you a pic of the LEFTY extenders... would you like a pic of them off or on the bike?
-Jake
r1yfz
Post by r1yfz »
on the bike perferably
caseyracing222 wrote: lets not go looking for a fight
:nutkick: have a nice day :D
caseyracing222
Here are all the types I know of.....
Starting of with my bike.... I use Leftys extensions with the brake set up
another set of Lefty's NOT my bike
Dave J extensions and bikes
Jeff Thomas built extensions and machines
and French built stuff....
-Jake
Ive looked at that bike close up at RPs pad, the supercharger setup is pretty fukin cool :cool: :cool: :cool:
glen howell
Post by glen howell »
123
Last edited by glen howell on December 1st, 2010, 9:16 pm, edited 1 time in total.
