Sealing pipe to silencer?
I can not seem to keep the rubber collar that goes in place at the junction together. If it lasts one ride, that is surprising. It seeems to be up against the airbox and just rips apart. What about using high temp silicone to seal it?
- tacogrande
- redrocket190
- NightBiker07
If you can find it, Chamber seal kicks ASS. hard to find though.
http://www.atvupgrade.com/53-0140.html
silicone and rubber things did NOT hold up on my air-cooled 300R trike. this shit was a one-time application. HIGHLY RECOMMEND.
I think my sub frame is tweaked a little because the pipe is very close to the airbox. I tried the high temp silicone, but have not ridden since I put it on. I was just wondering if anyone had similar issues.JBaze wrote:You should check to make sure your pipe is mounted right. Of all of the 500's I've had, I've never had to replace that rubber boot. It shouldn't be contacting the air box
Jeff I have a bunch of Chamber Seal left since it doesnt work if you want it...
Use the OEM boot and 2 zip ties. Mine has been on there since before the last time we were at Apex and you blew your case...
M.F.D.B. wrote:Me neither... (YZ450F)seanmx57 wrote: I didn't run one for years and never had any spooge coming out.
:lmao::lmao::lmao::lmao::lmao::lmao:
Your spooge comes out of your crankcase when you throw your rod!
Theres gonna be spooge coming out of your crankcase when you bend over too close to me...CR500R7 wrote: Your spooge comes out of your crankcase when you throw your rod!
Thats true. It is good to have a mechanic in your pocket.M.F.D.B. wrote: Nah, im the guy that has to fix it if its fugged...
I didn't really have the spooge coming out of there, but I could tell exhaust was coming out and didn't know if that would kinda mess up back pressure or anything and make it lean like a crack farther up on the pipe.
As for welding it, when I was a kid my neighbor had a Honda 200 3 wheeler that kept tossing the chain, too stretched out, and he was trying to think of some way to keep it on. I almost had him convinced that if he welded the chain to the rear sprocket it would be fine. [/img][/flowplayer]
Looks like that kid may have had your 500 before you did (the brazed on master link that cost you a left engine case).. hahahaCrow500 wrote: I almost had him convinced that if he welded the chain to the rear sprocket it would be fine.
