new style(92) pivot bushings in older(87) case
Im putting an 87 500 engine together to go in my 92 chassis and i know most people have the swingarm pivot bushing machined out to fit the larger bolt, but im thinking about boring the case and pressing the larger bushings in. Is there something i dont know? or will this work? the aluminium is gonna be much easier for me to drill.
Also, its a .02 over 87, stock porting and head, will it be a little quicker than the scalloped 92 engine? and would you suggest using the later thin head gasket?
Thanks
Thanks
- CR500R7
I'm sure Danny drilled the cases on his 86 engined Gen1 AF useing a 13/16 th drill bit.
Check with him and get the low down on it.
Yes, this will work if done properly and then use the larger bushes.
you need to use a boring head, not a drill bit so you can get the proper pressfit, i've done them like that a few times
As long as the engine is tuned as good as it can be it'll be as fast, possibly faster, but theres no reason to look for something else.
you'll probably have too much compression with the thin gasket on that head, i'd cut the head, but i'd ride it first and see if it needs more compression, doubt it.
first thing to check is that the low style pipe you have clears the reed block area, a fatty wont, but a pc or gnarly should
I used a drill bit on one engine, and it worked fine.
I used the same bit on another engine and it cracked the case half when I was gently tapping in the "bushing"
- asteroid500
Drilled it and it pressed right in with no cracks, guess I got lucky this time
So, should I go with the 92 head on it then? anyone know the approximate difference in volume?
, didnt think about the reed cage flange being longer. 8mm (or .3149 inches) difference according to the parts comparison link, not very much. I dont think it will be an issue, but you say it will hit on a fatty? I trust you, ill have to take a look when I get her in. You think ill have much trouble with the carb getting in there, I figure the boot will flex .315 inches.
Ill be using the newer reed cage, air boot, air box etc. The 92 chewed the piston, spit some out the bottom ruining the cases. I have this mostly complete 87 engine, cylinder was just bored 20 over with new piston. never put the 87 back together because the covers are the usual rotten magn so I will be using the newer covers and newer clutch, and I swapped to the larger bearing in case for the newer trans shaft. Im going to try and use the 87 4th and 5th gears as well. many thanks
cr750, email me, got some questions about those cases, and can give you some help swapping in those gears
got it back up and running
, I used the thinner late model head gasket so combined with the scallop-less cylinder and the 87 style head it is a hard kick. It is considerably harder hitting than the 92 motor that was in it, prolly due to the fact the other was worn out, or the porting on the 87 is better, either way you can tell a pretty big difference.
The fatty pipe went on with no issues what-so-ever, like I figured, why do some folks have problems with it?
my camera is fucked so it will be a while before I can post some pictures of the thing
my fatty was new with papers stil, hit so hard i changed jugs
