Just put my conversion back together from its winter time rebuild. Have not ran it with the 250 ignition and have a couple questions???
First off what has been the changes in jetting for anyone who has done the ignition swap. Up/down, main / needle, whatever??
Second, where are you setting the timing? I left the plate on the bottom mounting bolt which lines up with the case mark.
Not really looking for a "JUST TRY IT" response, looking for what other have experience with the swap before I try to start it!
250 ignition questions
- eyesky2002
MXMotoworx.com
2003 Honda CR500AF
MXMotoworx.com
2003 Honda CR500AF
- gregrobo
what year ignition
the o1 250 ignition we are running is 11 degrees advanced to the 500 if you run it as a bolt on it will preignite and run hot with flat power we did as shaggy did and slotted the holes to retard it then it realy comes alive and the fly wheel is 140~ grams lighter than the 500 flywheel we are still playing with jetting as we are running a radvalve as well
98 yzfr1
05 crf 500 race tech goldies
2010 rmz 500af
01 banshee
98 yzfr1
2010 rmz 500af
01 banshee
- eyesky2002
