Swingarm spacer help
agent
Post by agent »
Ok I am measuring for my swingarm spacers , and it's not adding up, are the spacers supposed to touch both the frame rail and the motor bushing? , if so the measurements I get are inside frame rail to motor bushing Left 61.44mm and right 65.18mm , I plan on turning them myself but how come my measurements are so big??? , on a side note can anybody tell me the ID and OD of the stock Honda bushings?
Thanks Rick
agent
Post by agent »
Ok I am a dumbass, I think I figured it out... Washers I forgot the Washers. I am an idiot sorry
Rick :roll:
What frame are you putting the 500 engine into.
If it is a Gen 3 or later you need a 54mm bush on the left and a 59mm on the right.
If you are putting the engine into a 02-07 CR125 frame you already have the correct spacers, no need to make anything.
There is no need to turn them up when you can buy them straight from Honda.
agent wrote:Ok I am a dumbass, I think I figured it out... Washers I forgot the Washers. I am an idiot sorry
:applaud:
