cr250 16bit cpu ignition with tps
craigf40
Post by craigf40 »
hi all thanks for this great site im from south africa and im looking for anyone who has used the last of the 2stroke cr250 ignition system on there 500 and had success with it i have got some info already but no concrete solution yet.the bike starts very easily and pulls really hard and crisp from the bottom till mid then it bogs and wont rev any higher probably 4500-5000 rpm.when i use the 01 cr500 ignition system and i use the complete system fly wheel the works then it runs 100% the only reason im trying the 250 ignition is iv read on this site that you guys get great results from the 250 ignition...
kind regards craig
asteroid500
Post by asteroid500 »
Good to hear your results. :twisted:
CR250 97
CR500 AF 99 (in progress)
CR500 AF CR G-4
CR500 1985 true legend
RGV250 96 X2
GSXR600 07 TRACK BIKE
VH Commadore cup car (race)
markv
Post by markv »
I would think the fact that the TPS isn't hooked up would have something to do with it? Maybe the CDI isn't letting it rev above that point because of that. I thought the ideal years of the CR 250 ignition swap were the years without all the electronic BS?
seanmx57
Post by seanmx57 »
have you played with the timing on the CR250 igniiton? Advancing or retarding the curve has a substancial affect.
