CR500: What engine mods to do?
- caseyracing222
My motor is completely stock, minus steel plates and H/D clutch springs. This will be its first rebuild since new and Im looking to pump it up quite a bit for the new class change in the hillclimb series I race (it will be cash instead of trophy). Last year I was running about a second to 2 seconds behind the top 10 which have modded motors. I have a list of what I want to do, and Im on a budget of about 1,000. Heres my list tell me what you guys think.
Vforce 3
port & polish
milled head
new OEM piston and rings
and If it needs it a new bottom end.
Vforce 3
port & polish
milled head
-Jake
- caseyracing222
- caseyracing222
- caseyracing222
- NightBiker07
Hmm.....CP Industries new big bore cylinder should tear up those hills.....
- caseyracing222
ok, can we please keep the garbage comments out of this thread. thanksellett wrote:A rider much better than me once told me to use fork bleed screws to plug-up my carb vent hoses. It helps keep dirt out of the carb.
If there was an issue with it he wouldn't be using it or recommending it to anyone...
-Jake
Ok, everything you want to know is in these posts:
Banned Encyclopedia of Horsepower
And, by the way, this place was built on garbage comments.
- caseyracing222
hahahaellett wrote:Ok, everything you want to know is in these posts:
-Jake
blownbillybob
blownbillybob
Re: CR500: What engine mods to do?
caseyracing222 wrote:
Vforce 3
port & polish
milled head
are you getting a LEFTY cyl. head
00'cr500 trailclimber
93'cr500 beater
92'cr500 hillclimber
89'cr 500 bent frame
04'crf230(wifeys)
02' cr125(sons)
02'sx65(sons)
03'xr50(sons)
93'cr500 beater
04'crf230(wifeys)
02' cr125(sons)
02'sx65(sons)
03'xr50(sons)
- caseyracing222
No the guy thats doing my port work is going to mill the headblownbillybob wrote:caseyracing222 wrote:
Vforce 3
port & polish
milled head
-Jake
- caseyracing222
- glen howell
glen howell wrote:And we just polish the squish and quinch.We don't alter them HONDA knows more about squish and quinch than anybody on this planet. But some think they do and end up with piston hitting head.
Your motor, YOU built, YOU re-checked out after I aquired, YOUR machinework caused a half moon shape through 1/3 of the piston circumfrance 4 mm wide by 2mm deep.
Look close at the pic you keep posting of the piston from the intake port edge to 6 o'clock, right on the edge.
Glen please stop, for christs sake......
Bob delete this if you want, no hard feelings.
- glen howell
He sold the race motor all you got was a cylinder used,a used piston,a used head That's not a fullrace mtr. All second hand parts, there's more to it than that .He sold all the other parts.
It was most likly was there all the time as your friend said I only mill heads.May'be after the milling the second time it showed up .It ran good for 100 but after milling it showed up ,He's very handy with a grinder. And as I said you should have checked the piston head clearence,A extra base gasket most likly would have taken care of it .I understand you are still running the piston with the marks on it. You know it's very funny that you and 100 are the only ones I have had a complante of,I have done at least 150 cylinders,heads, and may'be 75 complete engines Before and after the engine I did for 100 and I have had no complante's as of this date. I still make you the offer if you will give me a good mailing address .a new head,piston,and gaskets will be on the way they've been boxed up ready to ship for over a month now. I would like to make you happy Chris. Glen
glen howell wrote:.May'be after the milling the second time it showed up .It ran good for 100 but after milling it showed up ,
The piston used as an ashtray right next to me right now (the original one) has the exact same dent on the dome.
Im not mad about the motor glen im mad at you keep bringing it up and insinuating the contact is BS.......
Niceglen howell wrote: That's not a fullrace mtr.
Please for fuks sake drop it, like I told you before you owe me nothing and im cool.
Clyde/100/casey has his issues and thats between you and him, stop lumping us together.
