98 CR250 carby
- asteroid500
98 CR250 carby
Is any one running a 98 CR250 carby on there 500,
if so were are you with the jeting and needle hight.
It will give me somthing to start with.
Darwin Australia is HOT-HUMID and HOTTER, it never gets under 23 degrees celsius/ 75 degrees fahrenheit,
and you can cook bacon and eggs off a clean spade.
CR250 97
CR500 AF 99 (in progress)
CR500 AF CR G-4
CR500 1985 true legend
RGV250 96 X2
GSXR600 07 TRACK BIKE
VH Commadore cup car (race)
						CR250 97
CR500 AF CR G-4
RGV250 96 X2
- DitchWitch
I say bolt it on and see how it runs, then jet from there. believe it or not, 250s and 500s take pretty similar jetting, its isn't as some would assume as being twice what the 250 is since a 250 revs a whole lot higher. just bolt it on and try it.
- asteroid500
Danny,
i was of the same opinion but you can never be to careful.
as you know someone may of done it by now and its good to get a heads up.
Ditchwhitch,
97- was the only model with the ignition activated power jet carby.
98-99 in the Gen-1 were not.
Ditchwhitch,
CR250 97
CR500 AF CR G-4
RGV250 96 X2
						CR250 97
CR500 AF CR G-4
RGV250 96 X2
- glen howell
This is ther carb I run on my personal hillclimb bikes 41 mm Mik.Flat slide.When your in the rough stuff and the bouncing around it don't cut out and faulter Like the Kiehine does,I think it's because of the better float arangement the floats don't bounce around as much in the rough stuff, I also run a stock reed cage with Pro stage duel carbon fibre reeds with the limiter plates cut I still get longer life out of them.I've tried them all and they breath better than any I've tried ,They have a larger area of opening than any after market reed,With the stock reed cage with no limiter plates.And they also work better down low,in the mid range,and much more on top end. Glen
 [/img]
[/img]
									 [/img]
[/img]gas is for washing parts, alcohol is for drinking,nitro is for racing
						- asteroid500
- asteroid500
now this is fukked up ! a mexican popeye
[youtube]http://www.youtube.com/watch?v=SUvgft35 ... re=related[/youtube]
- asteroid500
my gen-1 is running the same carb setup as Glen runs. It fucken hauls the mail too  Gets terrible gas mileage now though, I run though 10 gallons in a day out at dumont if I'm on that bike.
 Gets terrible gas mileage now though, I run though 10 gallons in a day out at dumont if I'm on that bike.'09 kx450f 4-Poke
