How to relieve bridge?
blackz34
Post by blackz34 »
I know we should relieve the bridge after an oversize, but what do you use to do this? And do we absolutely need to do the scallops too?
Thank you.
Re: How to relieve bridge?
Post by M.F.D.B. »
blackz34 wrote:I know we should relieve the bridge after an oversize, but what do you use to do this? And do we absolutely need to do the scallops too?
Thank you.
I would recommend using a mild stone or sanding drum on a rotary tool like a dremel. You can also do it by hand with a file or stone but im waaayy to lazy for that! The scallops just make it easier to kick, unless this is important to you I wouldnt waste my time...
for sure use a dremel if you have one. it will make it 100 times easier.
blackz34
Post by blackz34 »
Thank you!
seanmx57
Post by seanmx57 »
I bored mine out to 90mm when it had a good stock hole to get rid of the scallops.
Post by M.F.D.B. »
seanmx57 wrote:I bored mine out to 90mm when it had a good stock hole to get rid of the scallops.
Me too...but i regretted it later. I would have rather been able to do all those top ends since now im almost time for a re-sleeve... :roll:
aluminum sleeve/nikisil ? :lol: . considering they last 3x longer than a steel bore it might be the last top end you do.
Post by M.F.D.B. »
100hp honda wrote:aluminum sleeve/nikisil ? :lol: . considering they last 3x longer than a steel bore it might be the last top end you do.
I have thought about that too... =) But I personally saw Jay Lewis's Nikasil bike squeek and thought "dam thats an expensive top end"!!
