DOES ANY ONE KNOW HOW TO REMOVE THE BOTTOM BEARING FROM THE STEARING STEM?  SHOULD I USE HEAT NOT SURE?
THANKS IN ADVANCE!!!!!
									HOW DO YOU REMOVE BEARING
				jearlycr500
Ride it like you stole it!!!!!!!!!!!!
						FREAKN FOUND IT!!!!! http://www.garagenight.tv/ep-5-replacin ... -bearings/
									They should take the warning labels off of everything and let stupidity sort itself out.
