GiePilaar
Posts: 21 Joined: October 7th, 2009, 2:41 am Last active:
Post
by GiePilaar » December 30th, 2009, 1:59 pm
Hi,
Ik bought a CRF450 (2003) roling frame a few months ago.
Today, I bought a CR500 motor ('95)
Now I can really begin to build. This wil be a chill project, o dont expect any updates soon (nog weekly
Grteetzzz Bram
Posts: 1898 Joined: June 23rd, 2007, 12:47 pm Last active:
Post
by Ported&Polished » December 30th, 2009, 3:18 pm
Shit your more than half done already! Cut that frame right now and in an hour you will be ready to weld it together.
GiePilaar
Post
by GiePilaar » December 30th, 2009, 3:22 pm
I wish I could. There's a Fireblade waiting to beprepaired for paint, and a CRF450 waiting for complete check up ($$$
So I will have my hands full the first couple of days
I just need a throttle (+cable) and the piece between the airbox and the carburatof from a CR500. I think I have( te make) al the rest
GiePilaar
Post
by GiePilaar » December 31st, 2009, 6:36 am
Posts: 15404 Joined: May 31st, 2007, 6:39 pm Last active:
Post
by AlisoBob » December 31st, 2009, 9:13 am
Their like US$8 each.....
Posts: 4641 Joined: November 16th, 2007, 3:24 pm Last active:
Post
by Roostius_Maximus » December 31st, 2009, 9:53 am
and hard, needle bearings are going to run on that, its a ground part like a wristpin
Post
by AlisoBob » December 31st, 2009, 10:46 am
...plated too
Wheelie-Gene
Posts: 311 Joined: May 26th, 2008, 11:52 am Last active:
Post
by Wheelie-Gene » January 1st, 2010, 8:41 pm
This place inspired me to build my own. So I know the initial excitement.
Post up the progress.
It'll be a learning experience...no doubt.
Good luck man.
2nd gen SSS street hooligan
83 CR480
83 XL600
97 VFR750
Kawasaki H1-F
Suzuki Titan
HondaHarley
83 CB1100F
GiePilaar
Post
by GiePilaar » January 15th, 2010, 2:16 pm
Posts: 716 Joined: October 5th, 2007, 11:22 pm Last active:
Post
by HrcRacing » January 15th, 2010, 3:41 pm
Lookin' good man and best of luck with the rest of your build.
asteroid500
Posts: 1047 Joined: January 5th, 2009, 1:29 am Last active:
Post
by asteroid500 » January 16th, 2010, 11:54 pm
Whose the invisible man in the green overalls in the second picture?
CR250 97
CR500 AF 99 (in progress)
CR500 AF CR G-4
CR500 1985 true legend
RGV250 96 X2
GSXR600 07 TRACK BIKE
VH Commadore cup car (race)
GiePilaar
Post
by GiePilaar » January 17th, 2010, 2:49 am
GiePilaar
Post
by GiePilaar » January 17th, 2010, 5:12 am
I bought this yesterday
I didn't expect it to be so expencive
110€
Post
by AlisoBob » January 17th, 2010, 8:06 am
GiePilaar wrote: I didn't expect it to be so expencive
110€
Thats crazy......
GiePilaar
Post
by GiePilaar » January 17th, 2010, 2:29 pm
idd
What distance between the mountingpoint, and the frame sould I +/- have?
I mounted the exhaust today, and I measured 35mm. Isn't that a bit much?
Post
by AlisoBob » January 17th, 2010, 5:39 pm
Yours is CRF450 based, the frame in the photo is a CRF250 frame... The measurment probably is different.
Post
by Roostius_Maximus » January 17th, 2010, 5:56 pm
i'd look to see where the clutch case bolt contacts, and move up a pinch from that
GiePilaar
Post
by GiePilaar » January 18th, 2010, 10:48 am
OK, thanks guys
The mounts will be milled tomorrow
Little update today:
I filed the Y-pece, I don't like the result yet. I wil file some more tomorrow
I costumised my chain guide, so I can change my supermotowheels easier
I mounted my new spark plug, it fits with the gas tank (only a couple mm space between the sparkplug cap ant the tank)
I mounted the exhoust, it fits nicely
Grtz
KE 336
Posts: 223 Joined: May 9th, 2008, 8:14 pm Last active:
Post
by KE 336 » January 18th, 2010, 12:00 pm
This spot is probably holding the motor up slightly. You have to grind on the top weld to let the motor tilt forward more. Get it to where the "HONDA" on the clutch cover looks level then you can measure distance for bottom mount. It will also give you a little more room for the plug and tank.
RideRed
Post
by RideRed » January 18th, 2010, 6:44 pm
110€
That spark plug kicks ass! What are the part numbers for both pieces?
Post
by AlisoBob » January 18th, 2010, 8:30 pm
KE 336 wrote: Get it to where the "HONDA" on the clutch cover looks level then you can measure distance for bottom mount.
Get it to where the pipe fits the frame well..... thats the important issue.....
Bean
Posts: 233 Joined: December 6th, 2008, 2:06 am Last active:
Post
by Bean » January 18th, 2010, 11:48 pm
110€
the cap/lead is trs1225 and the plug is a r7282 type
YOU didn't look close enough at our builds ... lol
we got them on both bikes
OK THAT'S 2 DONE ....
WHO'S IS NEXT????
RideRed
Post
by RideRed » January 18th, 2010, 11:52 pm
Right on Shaggy
Thanks for the info...I'll go have another look.
KE 336
Post
by KE 336 » January 19th, 2010, 5:39 am
AlisoBob wrote: KE 336 wrote: Get it to where the "HONDA" on the clutch cover looks level then you can measure distance for bottom mount.
Getting the cover level will do just that. If he leaves it tilted back the rear pipe mount will be somewhere behind the junction of frame and subframe
and would probably have to relocate the mount on the pipe. Tilting the motor down some more will also get the kick lever off the headstay tab of the frame.
