lighting Coil / electrical Question
agent
Post by agent »
Ok, trying to research the ignition / lighting coil for my AF conv. I will probably go with the 99 CR250 conversion ... But the lighting coil is only rated at 50 to 55 W, my question is for you electrical geeks, can I put a single pole lighting coil (cr500 pictured for ref only) on the OUTSIDE of the flywheel and still have it work to add some wattage to the system ??
thanks for the help
Rick
