Ignition side main seal???
eyesky2002
Post by eyesky2002 »
Can the ignition side mian bearing seal be replaced with out splitting the cases? I just stripped mine 94 ignition of my engine and see some black oil build up inside the case and around the seal/crank end.... Since I use the Honda 80/90w red tranny fluid I am going to say it has to be the main seal and not the clutch arm seal.
MXMotoworx.com
2003 Honda CR500AF
fastkart
Post by fastkart »
yes, it can be changed without splitting cases. All you need is a flywheel puller and the wrenches to take off the stator
Its an easy swap just a flywheel remover needed.
