air screw,,
air screw,,
hi all,my cr 500 has standard carb,
and was woundering on base setting ie,how many turns out [from stop] ,it has had a lot of porting work done,thanks
- redrocket190
A good rule of thumb is to start in the 1.5-2.0 turns out range. Then you can adjust when warm to see which setting gives the highest idle and/or you can test ride and see which setting gives you most immediate response when cracking the throttle open. If you end up > 2 turns out you need the next smaller pilot, if you end up <1.0 you might consider the next larger pilot.
Michael Stiles
2007 Honda CR500R-AF
thans chaps
thanks fastkart and redrocket190 for your replys,i will set it to 1.5 and see how it goes,
