ok here is my 94 steelie rebuild
i only have this one pic so far....cuz i tore it apart immediately after owning it for one day
trail port is waste of money if you ask me. you want to make it slower and pussify it even more than what it already is ? the damn thing is already de-tuned like a motha fucka from the factory. if your going to fork out hard earned cash then get something that will give it some nutz. find someone that can port it to the max.crf69 wrote:sending cylinder/sleeve/piston off to Glenmaybe a trail port i dunno
u gotta remember i am in ohio....nothing here except bean fields....and the trail u do find is pretty much 1st and 2nd gear only....im not for max power i want reliability;)100hp honda wrote:trail port is waste of money if you ask me. you want to make it slower and pussify it even more than what it already is ? the damn thing is already de-tuned like a motha fucka from the factory. if your going to fork out hard earned cash then get something that will give it some nutz. find someone that can port it to the max.crf69 wrote:sending cylinder/sleeve/piston off to Glenmaybe a trail port i dunno
i contribute by helping you keep hard earned cash in your wallet. no amount of special porting is going to turn your bike into some magical trail machine. what you going to do to make it work any better ?.....its already de-tuned so far its pathetic. stock motor will work fine on trails. what i would do is change up the gearing alittle. 500 has a tall first gear that sucks for trails. maybe drop down to a 13 front or 52 on the back. i dont know man i guess i look at shit different than most people.
						thats cool....im starting to think u may be right....the bike already has a flywheel on it.....13-52 it will have.......jus gonna have glen sleeve it and bore it to stock so.....yeah i think im good......rekluse may be next100hp honda wrote:i contribute by helping you keep hard earned cash in your wallet. no amount of special porting is going to turn your bike into some magical trail machine. what you going to do to make it work any better ?.....its already de-tuned so far its pathetic. stock motor will work fine on trails. what i would do is change up the gearing alittle. 500 has a tall first gear that sucks for trails. maybe drop down to a 13 front or 52 on the back. i dont know man i guess i look at shit different than most people.
i dont know if i would go 13/52, i was just saying you could try a 13 in front OR 52 rear. its hard to say what gearing will suite you best. get the gearing figured out then add some bark busters and skid plate then youll have a pretty good trail bike with all things considered.
probly best trail bike ever made right here
- thestuz
nice build up, but you could just order another piston? its cheaper than resleave i think.oh well, i wouldn port it for trails either, id just chuck a larger rear sprocket, maybe run it rich with stock jetting. i run standard gearing with standard jetting and its pretty good for trails(if cr500s are good for trails ) but if i were you i would stick to a 14 on the front and just play with your rear sprockets. you may need a extra chain link(for a largerr rear sprocket) but its better than wearing down your chain guide which smaller front sprockets tend to do.(you could always just short shift your bike aswell).the other fella is right, these things are detuned to the max. less powerfull/more controlllable power band will help you be faster on most mx tracks which is why honda made them like that. good luck, keep it posted.
and as far as xrs go, i never thought they made a bad one? ive got a 98xr600 fully rebuilt/restored and ill never part with it. shit i even used to get competative times on a mx track on it
400s aint too bad, just a little underpowered for me.i never had the oportunity to ride a 650... one day.
do it!...  cos if you dont, youll spend the rest of your life thinking about it anyway!
01 CR500
98XR600
94 FIREBLADE
ESTABLISHED 1977.
						01 CR500
98XR600
94 FIREBLADE
ESTABLISHED 1977.
i will....most all my major parts are out.....cylinder,head frame forks etc......got a new shock from hoofarted i  hope......hour meter,new footpeg pins,.....hopefully if i come to my senses i will order a rekluse pro.....i have two crf450r's with them......i cant ride without them im spoiled!!!!!   obviously a big 2 smoke is missing in this pic
currently waiting on oem frictions...lock washer........89 graphics......frame from powdercoater...........cylinder from glen gss.......head from decomp guy adam......and e-line pipe gaurd........prolly be end of this month i will have the pieces
They should take the warning labels off of everything and let stupidity sort itself out.
