older cdi in newer motor
Anyone know if an 91 cr500 cdi is compatible with the 98 cr500 ignition componets? Have a 98 cr500 that the cdi wires were cut at the very bottom of the cdi with really no way to repair them. Bought a 91 cr500 cdi from ebay, part #'s are different. Do i need to change any ignition parts to use the 91 cdi?
2000 banshee, 2006 cr500AFC, 1987 LT500r
Do they plug together? If so try it......
- CR500R7
rjt500 wrote:Thanks guys, yeah everything plugs in the same just wasn't sure so i thought i would ask. Had an 85 sold it to build this bike, 98 cr500 in a 03 cr250 frame, but i do have an 86 motor on the shelf which will be my next aluminum frame conversion!
Should make a great conversion.
- kelroy_leon
