Up grading the 05 to current wheels/brakes from the 87 stuff it came with.
Any ideas what [if any] hoops I'll have to jump through with the rear hub spacers/spacing to get the rear lined up correctly with the cs sprocket?
I just want to be ready when the new stuff arrives.
Gen 4 rear sprocket/CS sprocket alignment question.
- CR500R7
Just use the 05 spacers, if you don't have any go to the Honda stealership and get them.
Use all the right stuff and you can't go wrong.
If your brake disc lines up your sprocket should also line up.
