Seems to make more power all around. It's more noticeable on in the bottom/mid range than anywhere else, but does make more up top as well.
I ran it without the insert and a straight intake manifold, until the carb popped off (rubber on the straight manifold is too thick to allow the clamp to work well... until I modify it this week) then switched to an opened up stock manifold...still made more power over stock reeds, but not as much as the straight on manifold.
There might be some jetting difference between the stock reeds and VF3, but with different weather than the last time I ran, I had to rejet big time...so it's hard to say.
VForce 3 review...
