Cometic
- eyesky2002
Cometic
Has anyone had any issues with Cometic gasket kits being mispackaged? Just got a topend kit and it came all jacked up, it had no reed gasket and the exhaust gasket looks like it is for a 110 4 stroker?
I am getting a replacement set, but will I receive the same?
Worries me on the quality of the gasket if they cant even package it right
As for the stamped metal head gasket, do I put it on dry or use some copper spray?
MXMotoworx.com
2003 Honda CR500AF
MXMotoworx.com
2003 Honda CR500AF
the packaging mixup is wierd, but the head gasket is identical to oem, the base gasket is far superior to any other you'll buy. I've sold 30+ cometic 500 headsets, never seen a packaging issue like that before
- caseyracing222
with a headgasket identical to oem, and a superior base gasket + reed gasket (has tacky shit on them that sticks tight, nothing else needed, and with a metal structure it cant be sucked in or blown out), the only thing i can see making it "leaky" is if theres a dimple or something from corrosion or prying things apart100hp honda wrote:i remeber giving away a brandnew cometic kit for free.....thats how good it was. cant remeber who i gave it to but their bike is probly broke down with a leaky topend
the 86 jug i bough had a prying dimple on it, i admit i didnt see it until it was together and leaking to the outside, so it took it abpart, filled the hole with 1149 or whatever by threebond, made it flat and its been together for a few years now
