what size pwk was on the 2000 cr250?
need to know if its worth getting, anybody confirm a size? 39.5?
Last edited by Roostius_Maximus on August 3rd, 2009, 7:55 pm, edited 1 time in total.
That's almost the exact answer I was expecting
2000
NEW FOR 2000:
* All-new second-generation twin-spar aluminum frame and swingarm.
* Redesigned engine ports, air intake tract and exhaust provide excellent high rpm output, improved low and mid-range power delivery, and more useable power throughout the rev band.
* Slim new design with minimal bodywork. A redesigned seat creates a 10-15mm narrower profile in the seat and tank area.
ENGINE:
* Larger airbox with 35-percent more volume is located 15mm farther forward.
* 38mm flat-slide Keihen (PWK Air Striker) carburetor incorporates a triple-taper needle.
* Carburetor insulator features an internal step that smoothes airflow drawn into the engine.
* Reshaped CRV rotary/flap exhaust valve
has longer extensions at the side of the flap to better follow the exhaust port shape for increased internal turbulence, improved exhaust scavenging, and responsive acceleration.
* Sub-exhaust valve port is raised 1mm to improve exhaust transition flow to exhaust valves.
* Modified expansion chamber.
* 16-bit processor in the ignition CPU produces faster data calculation and more accurate ignition timing for the solid-state 3-D map-type digital ignition.
* New dual radiators provide 10-percent more surface area and a 8-percent improvement in heat dispersion over the previous single radiator design.
NEW FOR 2000:
ENGINE:
thanks Robert, any chance you're coming out this week, rumor is the boys next door have the scale ready
- CR500R7
So thats a NEGATORY on Bigfoot being attached to a 2000 CR250.
Rumor has it Bigfoot will be on Honda's 2010 CR500R10 model, soon to be released.
- CR500R7
Well, that show isn't broadcast south of the equator.
Tell me what am I missing, good/bad.
- NightBiker07
and a 100% chance of smashing the fuck out of them when you fall.robertg wrote:2000
CR500R7 wrote:Well, that show isn't broadcast south of the equator.![]()
Grab a beer and go to youtube, do a search for trailer park boys and watch some episodes, its fukin comedy gold
i knew this scronny lil wierd chick from town here that left to go be on the show, apparently got in some episode while in a crowd or something, shes a twitt, but the msn conversations were always entertaining
oh, and thanks for the carb help guys, i was going to pickup one i seen on ebay, but got burried in the basement renno and missed the dammn auction!
I live out in the country, we got a wireless internet thats linked from the top of our grain bins, it was down, had dialup, but the blackberry connection is quicker, eitherway i was gooing down some concrete repair/filler whatever so it needed my attention for a bit, i didnt know if i needed it either, have a bored pwk + stock, a bored pj + stock sitting on the shelf as is, just didnt have the AS version yet
