clutch issues?
motohunter4
clutch issues?
Post by motohunter4 »
my 87 cr250 is having clutch issues. i have replaced the cable and everything internally except the basket and inner hub, pressure plate. its isnt slipping, its almost like the clutch discs are too thick. i thought i had the wrong cable but the new one was identical. i took the hub to basket spacer out and milled it down, which worked for a while, but now its starting to do it again. HELP!
1983 cr480 bored to 494cc with '87 front end revalved by white brothers, stock pipe with dg silencer, 1 1/8 tag bars
1987 cr250 with '89 front end, v force 3 cage, ohlins rear shock, pro circuit works pipe with 304 silencer, 1 1/8 tag bars
gregrobo
Post by gregrobo »
check the lenght of the clutch actuator rod i had a bike that milled the end down about 4mm and i lost clutch like that
98 yzfr1
05 crf 500 race tech goldies
2010 rmz 500af
01 banshee
motohunter4
I thought that might be it so I replaced the rod the steel ball and the tip, as well as the arm and it didn't help. this thing is driving me crazy. I have the cable completely adjusted out and it still has play.
Post by M.F.D.B. »
Is your basket and hub notched? Usually this happens and causes the plates to sit in the notches and screw up the adjustment.
