crf 450 02 ?
ktm 620
crf 450 02 ?
Post by ktm 620 »
will 01 cr 250 radiatirs work on my cr 500 af project with out any moding i have read abought it but not %100 i no you gott to move the tabs but is that all you got to do
eyesky2002
Post by eyesky2002 »
Already sent you this in answer to your PM, but here it is once agian. I am running a 01 CR250 rad on my water pump (right) side, required no tab relocating. I did however choose to cover the cross over on the side and add a spout to the back face for the cross over. The 450 frame is tight there from the motor mount lug on the Y. The 01 CR250 left rad would have fit with out any tab or spout work, but I had a brand new 450 rad I used and only had to turn the cross over upwards a little.
MXMotoworx.com
2003 Honda CR500AF
ktm 620
cr 250 rads
Post by ktm 620 »
thanks eyesky i was just double cheking before i went out and bought a pair ov 2001 cr 250 rads best to be suer than go buy a part that dont fit any way thanks for the info i will go and buy a pair then my radiator isues shouild be sortid :cool:
